اخطار‌های زیر رخ داد:
Warning [2] preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead - Line: 272 - File: inc/plugins/imeiJalaliDate.php PHP 7.4.33 (Linux)
File Line Function
[PHP]   errorHandler->error
/inc/plugins/imeiJalaliDate.php 272 preg_replace
/inc/plugins/imeiJalaliDate.php 210 imeiJGconvert
/inc/class_plugins.php 139 imeiJalaliDate
/inc/functions.php 506 pluginSystem->run_hooks
/global.php 462 my_date
/showthread.php 26 require_once
File Line Function
/global.php 463 my_date
File Line Function
/inc/plugins/imeiJalaliDate.php 103 imeiJGconvert
/global.php 469 my_date
File Line Function
/inc/plugins/imeiJalaliDate.php 104 imeiJGconvert
File Line Function
/inc/plugins/imeiJalaliDate.php 105 imeiJGconvert
File Line Function
/inc/plugins/imeiJalaliDate.php 185 imeiJGconvert
File Line Function
/global.php 846 my_date
File Line Function
/inc/functions_post.php 166 my_date
/showthread.php 1070 build_postbit
File Line Function
File Line Function
File Line Function
File Line Function
/inc/functions_post.php 368 my_date
Warning [2] preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead - Line: 1038 - File: inc/plugins/mybbirckeditor.php PHP 7.4.33 (Linux)
File Line Function
/inc/plugins/mybbirckeditor.php 1038 preg_replace
/inc/class_plugins.php 139 mybbirckeditor_parser
/inc/class_parser.php 197 pluginSystem->run_hooks
/inc/functions_post.php 758 postParser->parse_message
Warning [2] preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead - Line: 1054 - File: inc/plugins/mybbirckeditor.php PHP 7.4.33 (Linux)
File Line Function
/inc/plugins/mybbirckeditor.php 1054 preg_replace
File Line Function
/inc/functions_post.php 923 my_date
/inc/functions_post.php 763 get_post_attachments
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
/inc/functions_post.php 543 my_date
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
/inc/class_parser.php 824 my_date
/inc/class_parser.php 866 postParser->mycode_parse_post_quotes
[PHP]   postParser->mycode_parse_post_quotes_callback1
/inc/class_parser.php 751 preg_replace_callback
/inc/class_parser.php 431 postParser->mycode_parse_quotes
/inc/class_parser.php 187 postParser->parse_mycode
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
/inc/functions_post.php 789 postParser->parse_message
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
/showthread.php 1153 my_date
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
  • 5 رأی - میانگین امتیازات: 3.8
مشکل در خروجی فایل سیف در ایتبس
سلام دوستان .
بنده هنگام خروجی گرفتن عکس العمل های تکیه گاهی برای سیف با این خطا مواجه می شم لطفا راهنمایی کنین که مشکل از کجاست بنده تمام مراحل بصورت صحیح طی می کنم.
[تصویر:  7jyvinxd0kmxiv1owot.png]
خطای نرم افزاری از ساپورت شدن فایل توسط برنامه می باشد . از ایتبس فایل با پسوند f2k ایجاد کنید و در سیف این فایل را ایمپورت کنید.
تاپیک مرتبط : http://www.mycivil.ir/forum/Thread-مشکل-...+گرفتÙ
تاپیک زیر را هم مشاهده کنید :
http://www.mycivil.ir/forum/Thread-دانلو...§Ø­ÛŒ+Ù¾ÛŒ
بنده مثل آموزشی که در تاپیک گفته شده رو طبق خودش می رم ولی با این ارور مواجه میشم .
این ارور تو ایتبس وقتی که می خوام export کنم ظاهر می شه.
(امروز، )mehranjoon نوشته است: بنده مثل آموزشی که در تاپیک گفته شده رو طبق خودش می رم ولی با این ارور مواجه میشم .
سلام مهندس
دو تا سوال
اول اینکه آیا شما پروژه رو خودتون در همین ورژن از ایتبس انجام دادید یا مثلا جایی دیگه انجام و در این ورژن ایتبس ایمپورت کردید؟
دوم اینکه شما پس از انتخاب اکسپورت کدام گزینه را انتخاب میکنید؟ اگه میشه تصویر مراحلتون رو قرار بدید
بنده با همین ورژن ایتبس پروژه را انجام دادم و در مرحله export نیز بر روی گزینه چهارم که ورژن سیفم 12 هست کلیک میکنم که این اخطار برای بنده نمایش داده میشه.
(امروز، )mehranjoon نوشته است: بنده با همین ورژن ایتبس پروژه را انجام دادم و در مرحله export نیز بر روی گزینه چهارم که ورژن سیفم 12 هست کلیک میکنم که این اخطار برای بنده نمایش داده میشه.
از فایل خودتون یه اکسپورت e2k بگیر و بعد فایلو داخل ایتبس ایمپورت کن و دوباره اکسپورت برای سیف 12 بگیر
میتونی اکسپورت برای ورژن 8 سیف بگیری و اونو وارد سیف 12 هم کنی
مرسی مشکلم حل شد.
مشکل از ورژن برنامه بوده که با ارتقای آن به 9.7.4 این مسئله حل شد.
ممنون که راهنماییم کردین.
سلام دوستان.منم در خروجی گرفتن ایتبز برای سیف مشکل دارم.ایتبز من ورزن9.6.0 و سیف ورژن8.1 است از همین سایت دانلود کردم.بنده مطابق همانچه که در سایت گفتید برای سیف فایل اف تو کا درست میکنم ولی هنگامی آن را در سیف ایمپورت میکتم فقط هندسه مدل را نشان میدهد و هیچ عکس العمل یا نیرویی را نشان نمیدهد.این کار را برای چند پروژه دیگر نیز انجام دادم ولی مشکل حل نشد.لطفا مرا راهنمایی کنید.
احتمالا مشکل از خود شماست و درست نمیزنید
برای اینکه مطمئن بشید برنامه درسته برید ورژن 9.5 رو نصب کنید (من خودم تا حالا هیچ مشکلی برای انتقال فایل از ایتبس 9.5 به سیف 8.1 نداشتم)
مرسی.با ایتبز 9.5 خروجی گرفتم درست شد.ولی نمیدونم چرا وقتی که از سیف خروجی دی ایکس اف میگیرم در اتوکد 2013 نقاط تکیه گاهی رو نمیخونه این مشکل واسه یکی از پروژه ها است ولی پروژه های دیگر را میخواند.فایل ای تو کا ی ایتبز رو چطوری اپلود کنم تا راحت تر کمک کنید.
Music خطا در نصب ایتبس mehd_5395 0 125 امروز،
آخرین ارسال: mehd_5395
  کنترل و طراحی دیوار برشی در ایتبس 19 SHAKIBA-am 0 308 امروز،
آخرین ارسال: SHAKIBA-am
Wink (فوری)مشکل قرمز شدن ستون حتی با مقطع خیلی بزرگ ! isamanb 1 450 امروز،
آخرین ارسال: Baghdadi_kft
Question مشکل در Run و پس از Run در ETABS enerzhi 55 34,927 امروز،
آخرین ارسال: Morteza0121
  همچنان مشکل قفل نشدن ایتبس بعد انالیز 7mycivil 6 5,057 امروز،
آخرین ارسال: miladjk1374
  مشاهده نتایج طراحی در فایل ذخیره شده ایتبس M_Fzl 1 873 امروز،
آخرین ارسال: satyashakti
  پرسش و پاسخ در مورد ایتبس roza12341234 5 2,242 امروز،
  مشخصات آرماتورگذاری تیر در ایتبس eng-askari20 0 688 امروز،
آخرین ارسال: eng-askari20
  راهنمایی نامگذاری مقاطع ایتبس reza_mj63 9 8,974 امروز،
آخرین ارسال: Shahin.barzgaran
  Etabs 2016 مدلسازی باکس پله و آسانسور در ایتبس hadi2021 1 1,022 امروز،
کاربرانِ درحال بازدید از این موضوع: 3 مهمان
