اخطار‌های زیر رخ داد:
Warning [2] preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead - Line: 272 - File: inc/plugins/imeiJalaliDate.php PHP 7.4.33 (Linux)
File Line Function
[PHP]   errorHandler->error
/inc/plugins/imeiJalaliDate.php 272 preg_replace
/inc/plugins/imeiJalaliDate.php 210 imeiJGconvert
/inc/class_plugins.php 139 imeiJalaliDate
/inc/functions.php 506 pluginSystem->run_hooks
/global.php 462 my_date
/showthread.php 26 require_once
File Line Function
/global.php 463 my_date
File Line Function
/inc/plugins/imeiJalaliDate.php 103 imeiJGconvert
/global.php 469 my_date
File Line Function
/inc/plugins/imeiJalaliDate.php 104 imeiJGconvert
File Line Function
/inc/plugins/imeiJalaliDate.php 105 imeiJGconvert
File Line Function
/inc/plugins/imeiJalaliDate.php 185 imeiJGconvert
File Line Function
/global.php 846 my_date
File Line Function
/inc/functions_post.php 166 my_date
/showthread.php 1070 build_postbit
File Line Function
File Line Function
File Line Function
File Line Function
/inc/functions_post.php 368 my_date
Warning [2] preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead - Line: 1038 - File: inc/plugins/mybbirckeditor.php PHP 7.4.33 (Linux)
File Line Function
/inc/plugins/mybbirckeditor.php 1038 preg_replace
/inc/class_plugins.php 139 mybbirckeditor_parser
/inc/class_parser.php 197 pluginSystem->run_hooks
/inc/functions_post.php 758 postParser->parse_message
Warning [2] preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead - Line: 1054 - File: inc/plugins/mybbirckeditor.php PHP 7.4.33 (Linux)
File Line Function
/inc/plugins/mybbirckeditor.php 1054 preg_replace
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
/inc/functions_post.php 543 my_date
File Line Function
File Line Function
File Line Function
File Line Function
/inc/class_parser.php 824 my_date
/inc/class_parser.php 866 postParser->mycode_parse_post_quotes
[PHP]   postParser->mycode_parse_post_quotes_callback1
/inc/class_parser.php 751 preg_replace_callback
/inc/class_parser.php 431 postParser->mycode_parse_quotes
/inc/class_parser.php 187 postParser->parse_mycode
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
/inc/functions_post.php 789 postParser->parse_message
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
/showthread.php 1153 my_date
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
  • 55 رأی - میانگین امتیازات: 2.55
ایستگاه گذاری بروی مسیر در لند
من وقتی در لند مسیر تعریف کردم و ایستگاه گذاری را انجام میدم اون مقادیر روی الاینمنت اندازه کوچه نوشته میشن چکار کنم که کیلومترگذاری با اندازه بزرگ نوشته شوند.
(امروز، )ali719 نوشته است: سلام
از قسمت text Style مقدار Height را افزایش بده مثلا 2 قرار بده . بعد دوباره ایستگاه گذاری کن.
[تصویر:  v628_Untitled.jpg]
[تصویر:  d6463_aaaaa.jpg]
موفق و موید باشید
سوالی داشتم در مورد تعریف مسیر در نرم افزار ؟؟؟؟؟
define from object رو وقتی میزنم کل مسیر رو با زووم انتخاب کردم بعد که میخوام رسم کناره مسیر رو انجام بدم فقط قسمت اول رو رسم میکند .
چطوری باید کل مسیر رو به پروژه تعریف کنم ؟؟؟؟؟
(امروز، )rezvan935 نوشته است: سلام
اگه مسیر شما یکپارچه باشه یعنی از پلی لاین استفاده کرده باشید میتونید بجای فرام آبجکت از فرام پلی لاین استفاده کنید تا کل مسیر انتخاب شود.
ولی اگر غیر از این بود با استفاده از فرام آبجکت نزدیک نقطه شروع مسیر کلیک کنید بعد کل شکل مسیر را پشت سر هم انتخاب کنید و در آخر دو بار اینتر بزنید و در پنجره باز شده اسمی براش بذارید و اوکی کنید.( نکته : قبل از اینکه دو بار اینتر را بزنید حالت زوم خود را کاهش دهید تا شکل مسیر توی صفحه نمایشتون کامل دیده شود در غیر اینصورت فقط قسمتی که زوم شده تعریف خواهد شد)
اگه مشکلتون حل نشد فایل نقشه رو پیوست کنید تا کمکتون کنم.
موفق و موید باشید
سلام جناب مهندس اگر امکانش هست فیلم ها ی آموزشی به همراه مثال ملموس برای اتوکد لند نیز قرار دهید. با تشکر
(امروز، )Reza-MSR نوشته است:
موفق و موید باشید
ممنون از راهنماییتون . من کارایی رو گفتید انجام دادم ولی وقتی میخوام کناره های مسیر رو طراحی کنم فقط همون قسمت اول رو میشناسه و ترسیم میکنه
من فایل رو برای شما پیوست کردم تا ببینید مشکش چیه!!!
http://s5.picofile.com/file/8126661650/D...k.rar.html
[تصویر:  15455423652.gif]
(امروز، )rezvan935 نوشته است: ممنون از راهنماییتون . من کارایی رو گفتید انجام دادم ولی وقتی میخوام کناره های مسیر رو طراحی کنم فقط همون قسمت اول رو میشناسه و ترسیم میکنه
علت اینکه فقط تکه اول مسیر جاری میشد اینه که شما برای رسم قوسهای عرضی از ابزار (Arc) استفاده کردید ولی این ابزار بهنگام تعریف الاینمنت به نرم افزار قابل شناسایی نبود.
بهتر است برای رسم قوس عرضی از منوی (Lines\Curves) که ابزارهای خوبی برای رسم انواع قوسها دارد استفاده کنید.
بنده به کمک ابزار پی لاین مسیر شما را دوباره ترسیم کردم و مراحل گفته شده در ارسال قبلی را انجام دادم.
خدمت شما
http://s5.picofile.com/file/8126662242/D...0.rar.html
سوالی بود در خدمتم
نقل قول: علت اینکه فقط تکه اول مسیر جاری میشد اینه که شما برای رسم قوسهای عرضی از ابزار (Arc) استفاده کردید ولی این ابزار بهنگام تعریف الاینمنت به نرم افزار قابل شناسایی نبود.
خدمت شما
ممنون از رهنمایی شما مهندس
مسیر اصلاح شده توسط شما رو با پروژه خودم باز میکنم هیچ تعغیراتی نمیتوانم روی آن انجام بدم . هیچ کدام از ابزار ها روش عمل نمیکند.
خدمت شما
خواهش میکنم.
ابتدا باید نرم افزار را باز کنید بعد از منوی (File) گزینه (Open) را بزنید و از گزینه (Browes) نقشه را انتخاب و روی (Ok) کلیک کنید.
بعد از انجام مراحل فوق نرم افزار از شما میخواهد که آیا مایلید پروژه تعریف کنید شما روی (Yes) کلیک کنید تا تمامی اطلاعات قبلی بازخوانی شود تا بتواند ادامه پروژه را انجام دهید در غیر اینصورت باید به مرحله اول برگردید و از نو شروع کنید.
خب آیا شما این مراحل را انجام دادید؟
اگه جوابتون مثبته که باید بگم احتمالا ایراد از نرم افزاره که چون کد شکنی شده همچنین ایرادهایی رو هم دارد. پس فایلی که من براتون ارسال کردم نمیتونه کمکتون کنه. در این مرحله چاره کار اینه که خودتون باید مسیر را طبق عرایض بنده در ارسال قبلی ویرایش کنید و الاینمت تعریف کنید. کار سختی نیست فقط کافیه که بجای قوسهای فعلی از منوی (Lines\Curves) نرم افزار لند قوس جدید ترسیم کنید و دوباره الاینمت تعریف کنید.
سوالی بود در خدمتم
موفق و موید باشید
نقل قول: ابتدا باید نرم افزار را باز کنید بعد از منوی (File) گزینه (Open) را بزنید و از گزینه (Browes) نقشه را انتخاب و روی (Ok) کلیک کنید.
سوالی بود در خدمتم
موفق و موید باشید
خیلی ممنون .
مشکل من حل شد . مسیر رو دوباره ترسیم کردم .
قوس ها رو با استفاده از منوی (Lines\Curves) اجرا کردم . مشکلم حل شد
ممنون از شما مهندس جان
  راهنمایی در مورد انتخاب مسیر پروژه راه samisoft 3 5,954 امروز،
آخرین ارسال: Elnazes
  مشکل در خط مسیر روی توپوگرافی alimorad39 7 2,764 امروز،
آخرین ارسال: 1q2w3e4rr
  روش خط شکسته در تعیین مسیر haditgr 1 1,529 امروز،
آخرین ارسال: عادل رزداری
Question ایستگاه گذاری بروی مسیر حسینی11 0 1,522 امروز،
  درخواست کمک در انتخاب نوع سیستم قوس ها در مسیر mosa2 6 2,956 امروز،
آخرین ارسال: mosa2
  تعریف مسیر در لند Mergen 4 2,894 امروز،
آخرین ارسال: Mergen
  راهنمایی طراحی مسیر در سیویل siahkamar 9 4,171 امروز،
آخرین ارسال: siahkamar
Wink offset مسیر راه CheshmeyeRoshan 4 3,017 امروز،
آخرین ارسال: omid_rch
  تبدیل مسیر به پولی لاین در لند ali719 9 6,060 امروز،
آخرین ارسال: Reza-MSR
  طراحی مسیر در پروژه راه hojat70 2 3,588 امروز،
